stanbridge30
Mar 15, 2018Aspirant
Files not showing on MAC
Please Help! I have no idea what i'm doing. I have had this server for about 7 years - it has all my films on it (i'm a film maker) Recently I upgraded my mac to Sienna and although the fileserver ...
stanbridge30
Mar 18, 2018Aspirant
how do i find out what firmware is running? also now says c: unprotected? Thanks again
Mar 19, 2018Guru - Experienced User
The NAS admin UI ( https://nas-ip-address/admin )will tell you that, as will RAIDar ( https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar ).
If you entered the correct model number (ReadyNAS 1100 - which is a 4-bay rack mount), then the firmware should be 4.1.x. If the model was entered incorrectly, then it might also be 4.2.x, 5.3.x, or 6.x.x. A picture of the 1100 is below.
That means a disk has failed (or been removed).
- stanbridge30Mar 19, 2018Aspirant
Hi stephen,
Thanks for getting back to me.
The model on the front says Ready Nas NV + v2. I've attached an image if that helps?
- StephenBMar 19, 2018Guru - Experienced User
That should be running 5.3.x firmware. Have you tried logging into the admin ui (using https://nas-ip-address/admin)? RAIDar will tell you the NAS IP address; you can also get it from your router (and perhaps the NAS LCD panel).
Hi again,
the problem is not my mac recognising the drive. It's that whilst it shows fileserver there's nothing there?
