spie
Dec 18, 2011Aspirant
Files not visible with AFP but with CIFS
Hi, I wonder why I can't see file while using AFP. If I try to view the folder via CIFS, I can see all the files. What can I do? I'm using a ULTRA 6 PLUS with Radiator 4.2.19. On the other side ...
Dec 22, 2011Guru - Experienced User
If you go to the share listing from the admin page and click on CIFS (or any other protocol), you'll an advanced option tab on the far right. This has an "Advanced Share Permission" section that lets you set the owner, group, and owner/group/guest access rights for all files in the share. Check the control next to "Set ownership and permission for existing files and folders in this share to the above settings. This option is useful in cases where you are changing security levels and need to workaround file access problems." Then press the apply button at the bottom.
The permissions are reset in the background, if you stay in frontview a dialog will popup telling you that is it done.
