peteridgway
Oct 17, 2013Aspirant
Files/folders not showing up on TV!
hey guys. I am the owner of a Duo v2. Its a great product but I am having a problem with it. Basically, whenever I transfer some files to the nas(say, breaking bad season3 for example, as the folde...
Oct 17, 2013Guru - Experienced User
Did you try logging into the dashboard, and doing a manual rescan of the files? This is under configure (click readydlna under services, and you should see a control to rescan).
