udolein
Jun 27, 2016Follower
Firmware 6.5.1 - SMB down after reboot
After firmware update of my ReadyNAS 716 from 6.5.0 to 6.5.1 the SMB service on all of my shares kept down after reboot. Therefore the device was unaccessible from Windows. After having reenabled...
whgmkeller1
Jul 04, 2016Aspirant
I'm also having problemsn with SMB after upgrading to 6.5.1. In the last weeks I turned off AFP acces - because Apple is moving away from AFP - and have set SMB acces to all shares. This worked excellent, but now after upgrading to 6.5.1 SOME of my shares are not accesible, while SOME are....
I get an error message saying something like "the operation can not be completed bacause original entry for share MAIN-Software can not be found" (original errormessage in Dutch). When I check through the admin page, all shares are present and hold information.
Any clues ????
Willem
Netherlands
BrianL2
Jul 06, 2016NETGEAR Employee Retired
Hi whgmkeller1,
Welcome to the community!
Can you confirm if the ReadyNAS or the said share is mounted in your MAC? Also, have you tried disabling the SMB service in the admin page? Or perhaps resetting the permission of the affected shares?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
- whgmkeller1Jul 07, 2016Aspirant
Hi. Problem is solved.
After the upgrade to 6.5.0, somehow the SMB access settings had chaged. I ammended this and now all shares are visible and accessable.
Thanks.
Willem
- BrianL2Jul 07, 2016NETGEAR Employee Retired
Hi whgmkeller1,
So you downgraded back to 6.5.0? Anyhow, I'm glad that its working again and I suggest that you continue to monitor the SMB access to see if the issue is completely gone.
Kind regards,
BrianL
