doujungle
Aug 16, 2016Aspirant
Firmware 6.5.1 - SMB down after reboot
Everything working fine until FW 6.5.1. Once I upgraded to the above FW, my LG TV can see the NAS still but no changes I make to the nas show up. I can see the NAS on OS X if I browse it, but am ...
robrobinson
Aug 23, 2016Aspirant
I am having this same issue. Was there ever a resolution ??? This is holding up a lot of my researchers that are using windows.
- StephenBAug 23, 2016Guru - Experienced User
Try this (as a test).
Open CMD
net use * /delete
net use t: \\nasipaddress\data /user:admin nasadminpassword
See if that mounts the data volume as drive letter t.
- doujungleAug 24, 2016Aspirant
This did not work. Also, I don't see how that helps the TV see updated content on the NAS.
- StephenBAug 24, 2016Guru - Experienced User
As I said it was a test (not a solution). What error did you get?
Ok, let's step back. There were two problems that the OP had. One was with his smart TV, the other was with OSX PCs.
Are you seeing both of his problems? Or just the issue with the TV? If the latter,are you using DLNA or SMB?
