rnervi
Jul 26, 2018Aspirant
firmware dont update
actual fw: 6.2.5
no way to update to 6.5.2 and up till 6.9.3
either by online dload or update firmwar from local pc
it works till 100% then... no changes
- Jul 27, 2018
Please follow this guide as a one-off: ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
After you've used this procedure you can then do subsequent updates the normal way.
It would be advisable to make sure you have a good backup of important data before updating the firmware. See ReadyNAS OS 6: Firmware Upgrade Guide and Tips
mdgm-ntgr
Jul 27, 2018NETGEAR Employee Retired
rnervi
Jul 27, 2018Aspirant
had not "invalid checksum" in unit logs but anyway the workaround worked fine.
