seezee's avatar
seezee
Firmware update 4.1.16 (& my stupidity?) hosed NV+ v1 h3 SPARC. Stuck on boot, C drive empty.
NV+ v3 SPARC was OS 4.1.15 but now it's 4.1.16, used on an APPLE environment over Gigabit Ethernet.
I got an email this morning alerting me to the firmware update (why now? this update is months old?). Tried to install this afternoon, first from the remote image, then local. Kept failing the upload & verify. Couldn't shut down from Frontview because it said a background task (the unfinished update? Shouldn't that have stopped due to upload/verification error?), Had to SSH in and run:
shutdown -r now
After reading the forums I determined the OS partition was full. Deleted a bunch of logs, disabled DNLA & iTunes servers, deleted the DNLA caches. Got really clever & moved the log directory to the C drive and symlinked to it from the OS partition. Finally got the firmware update to pass, system dialog (in Frontview) says to reboot, but the shutdown page is still giving me the "can't reboot due to background task" message. I shut it down from the command line again.
Starts up, hangs on "booting up."  I can SSH in and I see the C drive is now empty.  Output of
df -h
is
Filesystem            Size  Used Avail Use% Mounted on
/dev/hdc1             1.9G  414M  1.5G  21% /
tmpfs                  16k     0   16k   0% /USB
Since /c/var/log no longer exists, I delete the symlink and create a new empty /var/log directory. Reboot. Still hangs.
Try a USB boot, with a copy of the firmware executable on a thumb drive. Display says "Index Error." Try booting into tech support mode. Start RAID, mount /sysroot/, there's a single log file but since I'm telnetted in I can't open it.
I can see the symlinks to my shares in the root directory, but the shares appear to be gone. And of course, the durned thing won't finish booting anyway.
Am I screwed? I'm afraid to do an OS reset because I've got 4 × 2TB drives & the original factory OS doesn't support big drives (1TB maximum).
    That's a bit too clever.
    df -h
    is
    So the data volume is no longer mounting.
    Booting off USB is only for if the firmware on the internal flash is corrupt. From what you've posted there's every indication that that's not the problem, so attempting to do USB Boot Recovery is a complete waste of time.
    You should still be able to use cat and you should be able to execute most simple binaries under /sysroot/bin, /sysroot/sbin etc.
    Make sure that there's nothing under /sysroot/c that may prevent the data volume from being mounted.
    An OS Re-install installs the firmware from the flash onto the disks. When you update the firmware it's updated on both the flash and the disks. So for most users the factory firmware won't be on the unit for long. Think of a factory reset as wiping all data, settings, everything, and doing a clean setup using the firmware currently on the internal flash like it would've been if your unit had shipped with that firmware. Similarly an OS Re-install will re-install the firmware currently on the internal flash onto the disks.
    There are some files to check to see if they were corrupted whilst the 2GB root volume was full.
    /etc/default/services
    /etc/network/interfaces
    /etc/frontview/samba/Shares.conf
    etc.
    An OS Re-install won't fix corruption in these config files.
  • Sorry, got the version number wrong in the title & can't edit it. It is, of course, a v1 model.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    df -h
    is
    etc.
    • seezee's avatar
      seezee
      Thank you. And yes, it was too clever by half.
      I did the OS reset & it worked a treat. No more crazy symlinking for this cat!
ProSupport for Business
