someusername
May 24, 2017Aspirant
Firmware update 6.7.3 Bricked one of my 4220's
Decided to update my Readynas units today to the newest firmware 6.7.3 and one of them bricked afterwards with an error in Raidar "Management Service is offline". Of course I tried to call in for su...
- May 27, 2017
someusername, I see you have been assisted by support.
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery (note for those using RAIDiator-x86 systems such as the Pro 6 you'll need to use the RAIDiator-x86 4.2.x USB Boot Recovery tool with the OS6 firmware renamed to RAIDiator-x86-something) with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
someusername
May 25, 2017Aspirant
Nope,
When I Click Download logs in Raidar I get the Downloading progress popup then Download process failed.
mdgm-ntgr
May 27, 2017NETGEAR Employee Retired
