Tobias66
Dec 15, 2016Aspirant
firmware update doenst work
Hi actual firmware 6.1.6 every restart message will prompt: upgrade to 6.2.5 -> ok download works, restart, nothing to see. no information about problems in systemlog test with manually downl...
Dec 15, 2016Guru - Experienced User
Is your issue that the firmware updates failed? (That is the web ui still says you are running 6.1.6).
- Tobias66Dec 15, 2016Aspirant
Yes, message FW Version 6.1.6.
Found another Thread (workaround):
Info under:
http://kb.netgear.com/29974/ReadyNAS-OS-6-RN100-RN2120-cannot-update-due-to-invalid-checksum?cid=wmt_netgear_organic
(Checksumproblem)But this works only from FW 6.1.9. Informatiosn about older Versions and resoultion -> link is broken.
Tobias
- StephenBDec 15, 2016Guru - Experienced User
That article only applied to 6.4.0 upgrades.
Do you have any apps installed? Also is ssh enabled?
- mdgm-ntgrDec 15, 2016NETGEAR Employee Retired
It seems 6.2.5 was on the internal flash but the OS on the disks was still on 6.1.6.
Your system should update to 6.5.2 when you next reboot.
