Tobias66
Dec 15, 2016Aspirant
firmware update doenst work
Hi actual firmware 6.1.6 every restart message will prompt: upgrade to 6.2.5 -> ok download works, restart, nothing to see. no information about problems in systemlog test with manually downl...
Tobias66
Yes, message FW Version 6.1.6.
Found another Thread (workaround):
Info under:
http://kb.netgear.com/29974/ReadyNAS-OS-6-RN100-RN2120-cannot-update-due-to-invalid-checksum?cid=wmt_netgear_organic
(Checksumproblem)
But this works only from FW 6.1.9. Informatiosn about older Versions and resoultion -> link is broken.
Tobias
Dec 15, 2016Guru - Experienced User
That article only applied to 6.4.0 upgrades.
Do you have any apps installed? Also is ssh enabled?
- mdgm-ntgrDec 15, 2016NETGEAR Employee Retired
It seems 6.2.5 was on the internal flash but the OS on the disks was still on 6.1.6.
Your system should update to 6.5.2 when you next reboot.- Tobias66Dec 15, 2016Aspirant
Hallo,
Thanks a lot. -> after reboot 6.5.2 was activated. After this i take upgrade to 6.6.0 -> it works.
But my first problem was "usb Device 2TB WD Mybook" could not be found.
One Time Systemlog wrote:
Mi Dez 14 2016 8:56:25
System: Externes Speichergerät ist verbunden, aber das Dateisystem wird nicht erkannt.Filesystem was NTFS, Partition deleted on PC (usb connection) -> at netgear nothing works. Use antother data cable, nothing works. test USB hard drive on PC -> works fine.
after download actual log files:
file: usb_storage.txt
*** Connected devices ***
/dev/disk/external/3:1:WDC_WD20EZRX-00D8PB0:WD-WCC4N7HCDHKE:480:-22 -> ../../sdbfile: usb_device.txt
1-0:1.0
1-1 product=My Book 1230 idProduct=1230 idVendor=1058 devnum=3 speed=480
1-1:1.0
2-0:1.0
3-0:1.0but no entry under System/Overview ;-(
any idea?
-> want use this drive for offsite backup.
- StephenBDec 15, 2016Guru - Experienced User
I'm not sure on the cause of the USB issue, but there are some fixes related to USB detection in 6.6.1 beta.
