roen1
Oct 05, 2017Aspirant
Firmware update failed 'boot from USB failed'
Hi all, After I initiated the latest firmware update I noticed my NAS was still offline. I walked to it and saw blinking lights and the massage 'boot from USB failed'. I can't shut it down, I ca...
Oct 06, 2017Guru - Experienced User
What firmware were you running, and what did you upgrade to?
If you have USB devices connected (including a UPS), then try disconnecting them and rebooting.
- roen1Oct 06, 2017Aspirant6.8.0 to latest, 6.8.1
Already tried disconnecting everything :) unplugged disks, connected other disk
Raidar doesn't find it, boot menu not possible- StephenBOct 06, 2017Guru - Experienced User
The chassis might have failed. You can check the warranty status at my.netgear.com (it is 3 years for the original purchaser). If you are covered, then you can do an RMA, and get a replacement.
If you are the original owner, but out of warranty, then you can still use paid support at my.netgear.com.
The disks can be migrated to any new OS 6 NAS. I'd get at least an RN214, the RN104 is still supported but is no longer being manufactured.
- roen1Oct 07, 2017Aspirant
ugh :( **bleep** news
I'll try the USB recovery tool and try to get this thing alive. Would like to have it back up and running as second NAS backup for backup 'cause these firmwar updates are **%*¨%* me :(. Now I am 'forced' to get a netgear again to have my data back from this one.
