McRob1
May 24, 2017Luminary
Firmware Update from 6.7.1 to 6.7.3 Has Failed
I just attempted to update the firmware from 6.7.1 to 6.7.3 and now I get the following when trying to boot. mount_block_root +1f1 all 6 drive lights are green I have tried using a paper ...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
dirtyreturn
May 27, 2017Aspirant
I upgraded to 6.7.3 and got stuck with unusable hardware.
The issue I'm facing is difficulty installing windows
- mdgm-ntgrMay 27, 2017NETGEAR Employee Retired
If you're comfortable with the Linux CLI you can follow these steps
Note you'll need to put the files from the x86 folder onto the USB key with the exception of syslinux.exe (the Windows installer for putting the syslinux bootloader on a USB key). Also the x86 firmware image you put on the USB key should be the 6.7.4 one. You need to extract the .zip download and put the .img file on the USB key.Alternatively you could e.g. create a VirtualBox VM for Windows and configure USB passthrough and run our tool.
