McRob1
May 24, 2017Luminary
Firmware Update from 6.7.1 to 6.7.3 Has Failed
I just attempted to update the firmware from 6.7.1 to 6.7.3 and now I get the following when trying to boot. mount_block_root +1f1 all 6 drive lights are green I have tried using a paper ...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
dirtyreturn
May 27, 2017Aspirant
Hi, thanks for the direction.
Firstly, I am having difficulty with the syslinux .zip. The first command - ./syslinux -I does not seem to be recognized.
And, for some reason I cannot get my windows vm to recognize usb drives.
I don't know...
Any way, somehow, is it possible to use gnome disk?
I don't know...
