McRob1
May 24, 2017Luminary
Firmware Update from 6.7.1 to 6.7.3 Has Failed
I just attempted to update the firmware from 6.7.1 to 6.7.3 and now I get the following when trying to boot. mount_block_root +1f1 all 6 drive lights are green I have tried using a paper ...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
4redstars
Jun 11, 2017Guide
Thanks!
I'm not sure what worked but I used Rufus to create the boot drive plugged the same USB drive I've been using and it failed with the same error. plugged the hdmi in and tried different timings of releasing the backup button. One of the three tries worked and my NAS is back up and running.
Thanks for taking the time to respond. Something worked I used I remembered the exact time I released it
mdgm-ntgr
Jun 12, 2017NETGEAR Employee Retired
The backup button method in my experience is pretty straightforward. Press and hold the backup button, turn the NAS on, keep on holding the backup button for long enough to get it to boot off USB. If you don't press it down properly or for long enough you'd run into issues. Still not all USB keys are compatible so it can take trying multiple different USB keys to find one that works.
The O.K. button on the RN316/RN516 is much more tricky as if you press the button too early or too late it won't work. We addressed this in later BIOSes by getting the systems to automatically boot off a connected NTGR USB service key without any need to press the O.K. button.
RN312 systems with one of the most recent BIOSes will automatically boot off a connected NTGR USB service key without any need to press the backup button.
- McRob1Jun 12, 2017Luminary
I am hoping you can decode your message.
You said something about a "NTGR USB service key" What is that?
You also said "We addressed this in later BIOSes by getting the systems to automatically boot off a connected NTGR USB service key" What is considered later BIOSes. Is there a specific version number that it is supposed to be able to boot without pressing the OK button?
Sorry I don't understand all the computer lingo.
- mdgm-ntgrJun 12, 2017NETGEAR Employee Retired
If you have one of the following BIOSes:
RN516: 08/31/2013 (or later)
RN316: 09/09/2013 (or later)RN312/RN314: 09/17/2013 (or later)
it should boot automatically off a USB Boot Recovery key created using our tool without needing to press any buttons.
The BIOS date is shown in bios_ver.logThe BIOS (Basic Input/Output System) is what gets a x86 PC started when you turn it on. One of the things the BIOS decides is which device to try to boot from.
