PiersC
Mar 24, 2017Aspirant
Firmware update to 6.6.1 and all encrypted shares lost
Hi all, I have just updated the firmware from 6.5.1 to 6.6.1 on my NAS and after reboot, all of the shares on the encrypted RAID 1 (drive1 and 2) have dissappeared. On the other drive (not encryp...
jak0lantash
Mar 24, 2017Mentor
It sounds like the NAS can't access the encryption key, therefore can't decrypt the relevant volumes, so can't read them.
Nothing disappeared from the volume, it's just not shown as it's unreadable.
Do you have a USB stick with the encryption key connected to the chassis?
http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf (page 32): You must insert the USB drive with the encryption key into a USB port on the ReadyNAS for the volume to be unlocked and accessible.You must insert the USB drive to unlock an encrypted volume during reboot. If you do not insert the USB key on reboot, there is a 10-minute time-out during which you can insert the key. Otherwise, you wll not be able to access the encrypted volume until the ReadyNAS is again rebooted. You can remove the USB drive after unlocking the volume. We recommend storing the USB drive with the encryption key in a safe and secure location when not in use.
- PiersCMar 24, 2017Aspirant
Hi Jak0lantash,
Thanks for your help.
The USB key was in and it seems to take forever, never making it past 48% without a memory error (__out_of_memory+354). Though when it does make it into the OS, the drives are red (inactive) and show nothing on them (capacity wise under volumes).
I have also tried a backup key i made on another USB stick (just in case there was an issue with the one of them) and the same result.
- mdgm-ntgrMar 24, 2017NETGEAR Employee Retired
Can you try booting into volume read-only mode (a boot menu option) then send your logs in (see the Sending Logs link in my sig)?
- PiersCMar 25, 2017Aspirant
Hi Mdgm, I have sent in my logs as requested,
I did find out that if I booted my NAS without either of the encrypted disks, it actually will load the ReadyNAS OS 6 GUI, though if I leave either encrypted disk in any slot, it always fails with a __out_of_memory+354 error.
Fearful for my data I removed the second disk (#2) of my raid 1 and booted with 1 encrypted disk (#1) of that pair (#1,#2) and I left the non-encrypted disk in head #3. (#4 is currently empty)
When I booted in read only mode it finally got past the encryption key 48% on the front of the NAS and I can access the shares only via the browser GUI, not over the home network. Those shares simply do not appear, the only upside is that I can copy of some of the files due to limited space on my computer.
What can I do?
Thanks for your help!
