flamepanther
May 24, 2017Aspirant
Firmware update to 6.7.3 - Retry Startup
What have you guys done to my NAS? I have a ReadyNAS 316--would love to give you the exact model, but I can't access the interface now that it won't boot. It started giving me "Retry Startup" on ...
- May 24, 2017
I've sent you a PM
Edit: If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
flamepanther
May 25, 2017Aspirant
Actually, if there's a way to safely wipe the OS volume and reinstall without losing the user data volumes, I'd be down for that. I can rebuild my settings easily enough.
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
flamepanther wiping the root volume was one of the options. Hopefully though I could do so whilst preserving the config.
