flamepanther
May 24, 2017Aspirant
Firmware update to 6.7.3 - Retry Startup
What have you guys done to my NAS? I have a ReadyNAS 316--would love to give you the exact model, but I can't access the interface now that it won't boot. It started giving me "Retry Startup" on ...
- May 24, 2017
I've sent you a PM
Edit: If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
mdgm-ntgr
May 24, 2017NETGEAR Employee Retired
I've sent you a PM
philipm
Jun 06, 2017Aspirant
I have the same problem but after attempting an update to 6.7.4. Retry startup stuck at 86%. Do I first go down the routeof updating to 6.7.4 again using USB recovery option?
Thanks
- mdgm-ntgrJun 06, 2017NETGEAR Employee Retired
No. I can have a remote look at your unit after some sleep.
