JohnNulty
May 24, 2017Apprentice
Firmware Update to 6.7.3 Failed
Just tried to update to 6.7.3 from 6.7.1 and it has failed. No access allowed from RAIDar, and 'Management service is offline'. Tried OS reinstall from boot menu - not working. Really, really, rea...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
mdgm-ntgr
May 24, 2017NETGEAR Employee Retired
Your 4GB root volume was considered full.
german811
May 26, 2017Aspirant
Hello, Please help me solve this isue.... already tried USB Recovery tool and stays in "Booting.." with 6.7.1 and 6.6.1 (x86).
I insert USB on front USB port and press Backup button and keeping it pressed i turn on NAS and release button when "Booting.." appears on LCD screen. Then it stays with FANS at high speed in that mode all night.
Please help me find other way to have my NAS back... Lot´s of Work and memories in there.
Thanks!
- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
- radmaxMay 29, 2017Aspirant
t Hello
I have the same problem as german811.
I use 3 different Legacy RNDU4000 for my data. In two Readynas the update 6.7.3 work's. But i have a fail update with the last. The booting lock at 26%
I have follow the step off mdgm
SpoilerIf you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!- I have create the USB Recovery. All seem goog for this step
- I insert the usb in front port(I have try also in back port)
- I hold the Backup button, then power on the ReadyNAS system and continue to hold the Backup button for up to 15
- The "Booting" message appears on the sreen an stay...
Ok after many test i have solved the problem
The recovery work's with usb on the back top port.
Thank's
