JohnNulty
May 24, 2017Apprentice
Firmware Update to 6.7.3 Failed
Just tried to update to 6.7.3 from 6.7.1 and it has failed. No access allowed from RAIDar, and 'Management service is offline'. Tried OS reinstall from boot menu - not working. Really, really, rea...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
coolbikr4684
Jun 11, 2017Aspirant
Figured my issue out, seems that the current update isnt compatible with the readynas 3200 at the moment so it botches the update. OS had to be rebuilt from my understanding on the flashdrive thats on the motherboard that got messed. A buddy of mine was the one who helped rebuild it with a prior version of the OS.
mdgm-ntgr
Jun 12, 2017NETGEAR Employee Retired
The 3200 does have a removable internal USB flash key so you do have additional options with that model that you don't have with most of the others.
