Davexyz2
May 19, 2016Aspirant
Firmware update to os 6.5 breaks SMB on USB connections RN104 #26893300
Updated my OS6.4.2 to 6.5 on my RN104's
However after rebooting I now cannot access my USB devices on any of the usb ports using SMB on windows PC. The main device ie the NAS share/s show in wi...
- May 26, 2016
Well I think it is only fair that when issues are fixed that thanks be due that they are made public as forums can tend to err on the side of a "moan-fest"
I will start by thanking the member of Support that dealt with my case I hope that I am not breaking any rules by naming them, Quin Hong. I would also tlike to thank the un-named R&D engineer that was also was involved and all the support staff that were involved in resolving this issue.
Of course in the end it was an "simple" fix In fact it involved a change of order of two lines in a configuration file but tracking these sort of things down can obviously be a nightmare, but they found it.
I was even told what to do. to correct my other units.
And the final "confirmation" was to update one of the OS 6.4.2 Units to 6.5 and edit the file
YES YES YES it works
It still begs the question "why does this only show up in disk's above a certain size",
(EDIT) Just been informed that it may be due to the size of the disk that extra delay is required. By changing the two lines that gives enough response time for the disc to be "fully" mounted
I also extend my thanks to all that contributed on this thread and to mdgm who escalated this.
Once I was "in the system " Netgear showed that they can work with the customer to resolve issues
Not to sour any praise but this is a "bug" in the firmware which I was unfortunate (fortunate for any other users who this may affect at some stage) to find and this I still believe the issue was addressed intially in a less than suitable manner.
Obviously my issue was initially very specific and Netgear has many many units with operating with a myriad of third party peripherals and disks, compatibility is always going to be an issue. And there is always the variability associated with the level of "user competence". Anyway it seems to be resolved and thanks again to all involved
I understand that the change in the configuration file will be incorporated in a later firmware update.
Maybe another unit in a couple of months time!!
kohdee
May 19, 2016NETGEAR Expert
We removed some kernel modules from the main package, so if your USBs are using XFS, then we don't mount them natively anymore without the Kernel Plus package.
but since you are using NTFS, we should pick that up. We did update the NTFS-support in 6.5.0. Did you e-mail your logs to support?
Davexyz2
No I have not sent in my logs. Who should I send them too Yourself?
- mdgm-ntgrMay 20, 2016NETGEAR Employee Retired
See the Sending Logs link in my sig. Send them in Attn: kohdee (as per the instructions)
- Davexyz2May 20, 2016Aspirant
Hi mdgm, kohdee logs sent
I also got the "usual" response from Netgear support
"out of 90 day warranty" I may have to pay an a case by case support. I should purchase a service contract etc
SORRY You broke it you fix it!
What is it with Netgear they simply do not get it.
Then customers get annoyed and rant on the forums and then it is their fault.
It works in OS6.4.2 but NOT in OS 6.5.0
- Retired_MemberMay 20, 2016
If you insist that this issue occurred straight after upgrade to F/W 6.5.0, I believe they should assist you without a support contract.
