kenya1
Oct 01, 2017Aspirant
Flashing Blue Light
I am getting a flashing blue light and have attempted to reboot but not working. How can I get this fixed
Sandshark
Oct 01, 2017Sensei - Experienced User
First, let's see if it's the hardware or software causing the issue. I assume you have tried to reboot and got nowhere. For the next step, power down, remove the drives (labeling the slots they came from) and power up with no drives. Does RAIDar show the NAS with a "No disks" status?
If not, it's not a good sign. If you can see it, power down and put the drives back in, then power up to the boot menu and try an OS install. If you did not see it in RAIDar with no drives installed, a USB recovery might help, but it's probably a hardware problem.
If you can't get to the boot menu with your original array installed, remove all the drives with power off and put in just one drive that is not part of your array. See if that works, either without intervention or via the boot menu. If it works this way, you probably have one drive that is so messed up it's bringing down the whole NAS.
If it''s a drive that looks like it could be the peoblem, then use manufacturers tools (e.g. SeaTools) to check the drives. If one is bad, return just the others to the NAS with power off and see if it now boots properly.
This is a long list. If you get lost or unexpected results at any point, come back and give an update. We'll see if we can help get you back on the road.
Oct 02, 2017Guru - Experienced User
Do you know what firmware you are running on the NAS?
- kenya1Oct 02, 2017Aspirant
No I don't, how can I find out?
- StephenBOct 02, 2017Guru - Experienced User
The firmware it shipped with should be on a label on the back, though of course you might have updated it after that.
- kenya1Oct 08, 2017Aspirant
Sorry couldn't reply earlier as I was out of action.
I look for a sticker at the back couldn't find any such sticker.
