jeffstanger
Oct 30, 2014Aspirant
Folder not visible on Samsung TV
Hi There, Firstly, thanks to all those who have come before me with dlna problems. I have read many posts and I am sure I am closer to a solution due to all your hard work. I am also sorry if what ...
jeffstanger
Nov 04, 2014Aspirant
Hi Guys,
Thanks for the advice. Here's an update.
I went through and removed any jpg files by deleting any that looked corrupt. Then I rescanned but I still can't see the folder I have been missing the whole time. The next thing I will do is copy the folder into another and try that. Here are the results of the latest scan.
Logs begin at Mon, 03 Nov 2014 02:07:38 +1100, end at Mon, 03 Nov 2014 07:49:45 +1100.
Nov 03 22:11:39 MEDIANAS minidlnad[10200]: minidlna.c:154: warn: received signal 15, good-bye
Nov 03 22:11:40 MEDIANAS minidlnad[24507]: minidlna.c:1014: warn: Starting ReadyDLNA version 1.1.3.
Nov 03 22:11:40 MEDIANAS minidlnad[24507]: minidlna.c:357: warn: New media_dir detected; rescanning...
Nov 03 22:11:42 MEDIANAS minidlnad[24507]: minidlna.c:1053: warn: HTTP listening on port 8200
Nov 03 22:11:42 MEDIANAS minidlnad[24507]: minidlna.c:1058: warn: TiVo support is enabled.
Nov 03 22:12:08 MEDIANAS minidlnad[24507]: minidlna.c:154: warn: received signal 15, good-bye
Nov 03 22:12:09 MEDIANAS minidlnad[24576]: minidlna.c:1014: warn: Starting ReadyDLNA version 1.1.3.
Nov 03 22:12:09 MEDIANAS minidlnad[24576]: minidlna.c:357: warn: New media_dir detected; rescanning...
Nov 03 22:12:09 MEDIANAS minidlnad[24576]: minidlna.c:1053: warn: HTTP listening on port 8200
Nov 03 22:12:09 MEDIANAS minidlnad[24576]: minidlna.c:1058: warn: TiVo support is enabled.
Nov 03 22:12:47 MEDIANAS minidlnad[24576]: minidlna.c:154: warn: received signal 15, good-bye
Nov 03 22:12:49 MEDIANAS minidlnad[24653]: minidlna.c:1014: warn: Starting ReadyDLNA version 1.1.3.
Nov 03 22:12:49 MEDIANAS minidlnad[24653]: minidlna.c:355: warn: Creating new database at /apps/.readydlna/files.db
Nov 03 22:12:49 MEDIANAS minidlnad[24653]: minidlna.c:1053: warn: HTTP listening on port 8200
Nov 03 22:12:49 MEDIANAS minidlnad[24653]: minidlna.c:1058: warn: TiVo support is enabled.
