Glyph
Apr 25, 2011Aspirant
Folders/Files missing in DLNA
I'm a noobie looking for some info/help with my readyDLNA setup. I have a NV+ (RAIDiator 4.1.7 [1.00a043]) with 4 Seagate ST2000DL003-9VT166 2 TB hard drives setup with X-RAID. I have set up the ...
vic20ian
Apr 26, 2011Aspirant
It seems to be a problem with 1.0.19 DLNA and some previous versions, did you update recently or buy new?
If you log into the NAS you probably see it is constantly trying to update.
There seems to be no way to reset, it goes on forever and I think this is the issue with it not reporting all the folders and files.
Did it stop working after adding any new files to the folder?
As we speak I am on a call to Netgear again trying to get them to recognise the issue and do something about it.
I will post if i learn anything.
Search DLNA on this forum and you will see a bunch of posts on the same subject.
Best regards,
Ian
Best regards,
Ian
