Glyph
Apr 25, 2011Aspirant
Folders/Files missing in DLNA
I'm a noobie looking for some info/help with my readyDLNA setup. I have a NV+ (RAIDiator 4.1.7 [1.00a043]) with 4 Seagate ST2000DL003-9VT166 2 TB hard drives setup with X-RAID. I have set up the ...
klockareson
Aug 25, 2011Aspirant
I've got the exact same problem, and the procedure presented by the support team to Glyph didn't solve the matter for me.
I did the same as Glyph mentioned, disable ReadyDLNA, reboot ReadyNAS and re-enabling ReadyDLNA, whereby a new search is started. Eight hours later I fugure it must be finished, but no. The log says it hasn't finished. Still the same problem with only a fraction of the material being shown.
I use PS3 and a TVIX 7000 and both items share the same problem with only a small amount is being shown. Any idea on what to do next?
I noticed after testing various things, that the problem seem to be the Search for medafiles again tool. After I've removed a few folders and trying to update the media library, this apparently doesn't work at all. The log tells me that the searh has started, but it never finishes.
