Glyph
Apr 25, 2011Aspirant
Folders/Files missing in DLNA
I'm a noobie looking for some info/help with my readyDLNA setup. I have a NV+ (RAIDiator 4.1.7 [1.00a043]) with 4 Seagate ST2000DL003-9VT166 2 TB hard drives setup with X-RAID. I have set up the ...
Autofahrn
Oct 26, 2011Aspirant
Seems I have a similar problem with the version 1.0.22 included in the latest sparc firmware (4.1.8). Is there a debug version available or should I remove and better install 1.0.21 instead?
Already did rescan, manually removed the database etc. Scan always ends up in a signal 15 without further information which of the 300.000 files (many, many pictures) causes the issue. Btw, same set of files were successfully scanned with the DLNA version (1.0.18.2??) contained in Radiator 4.1.7...
Thanks
Thanks
