Conz
Aug 03, 2012Aspirant
For the networking experts: NAS VS Switch jumbo frames
I've been pondering on this for a while but have not found any definite answer: Say you have a MTU of 9000 on your NAS, should your switch MTU be exactly 9000 as well or should it be over 9000 so t...
Aug 06, 2012Guru - Experienced User
Again, this depends on whether the switch UI wants you to enter the maximum ethernet frame size (layer 2) or the layer-3 MTU. There are a lot of switches out there...
Conz wrote: I actually managed to find an answer for this during the weekend on a site talking about (expensive) SAN setups ..
Switch MTU should be the transmitting clients MTU size + at least those 18 bytes.
The advice there was to put your SAN (/NAS) and clients on the same frame size (like, 9000) and then any networking gear in between at 9018 or higher.
Turns out I already had my setup configured like this (Pro pioneer + gigabit netgear switch of which I forgot the type) so no idea if it makes a lot of difference.
But I'm guessing a lot of people would make the 'mistake' of just setting everything to the same MTU size.
Verifying that the jumbo packets are getting through is easy to do. For a 9000 byte MTU (and Windows), open a cmd box and enter
ping -f -l 8972 xxx.xxx.xxx.xxx
where the xxx's are the IP address of the NAS.
If you see "Packet needs to be fragmented but DF set" then there is a problem with the configuration somewhere along the path.
