cnaidoo
May 31, 2017Aspirant
EOL Network Switches
Good Day,
Kindly provide EOL info for the following network switches and suggested model replacements
GS752TP
GS748T
FS108P
FS116P
HI cnaidoo and Danea,
Just to clarify it the FS108P is still active,
Please find attached the latest PoE poster update, you will see that we added a lot of new Gigabit PoE models:
GS305P and GS308P Unmanaged in the 5-port and 8-port with 4-port PoE
GSS108EPP Web Managed Plus 8-port with 4-port PoE/Poe+ with our Virtual Anywhere Mounting System
GS408EPP Web Managed Plus 8-port with 8-port PoE/PoE+ with our Virtual Anywhere Mounting System
Regards
Xavier Lleixa
NETGEAR CBU PLM
- DaneANETGEAR Employee Retired
Hi cnaidoo,
Welcome to the community! :)
I believe the FS116P and GS752TP are not yet EOL.
The GS748T (which is considered as version 1 or GS748Tv1) is already EOL. However, the GS748Tv5 is the switch model that is currently available in the market.
The FS108P is already EOL. I suggest the GS110TPv2 which is a Smart Managed switch that supports PoE and currently available in the market.
Kindly access the article below to know the NETGEAR Switches and other NETGEAR Business Products that are currently available in the market:
NETGEAR Business Products Catalog Vol. 17-1
DaneA
NETGEAR Community Team- XavierLLNETGEAR Employee Retired
Regards
Xavier Lleixa
NETGEAR CBU PLM
- cnaidooAspirant
Thank you for the feedback
Thanks for the correction :)
I just want to follow-up. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
