cnaidoo
May 31, 2017Aspirant
EOL Network Switches
Good Day, Kindly provide EOL info for the following network switches and suggested model replacements GS752TP GS748T FS108P FS116P
- Jun 05, 2017
HI cnaidoo and Danea,
Just to clarify it the FS108P is still active,
Please find attached the latest PoE poster update, you will see that we added a lot of new Gigabit PoE models:
GS305P and GS308P Unmanaged in the 5-port and 8-port with 4-port PoE
GSS108EPP Web Managed Plus 8-port with 4-port PoE/Poe+ with our Virtual Anywhere Mounting System
GS408EPP Web Managed Plus 8-port with 8-port PoE/PoE+ with our Virtual Anywhere Mounting System
Regards
Xavier Lleixa
NETGEAR CBU PLM
DaneA
Jun 08, 2017NETGEAR Employee Retired
Thanks for the correction :)
I just want to follow-up. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
