PCLease
Nov 30, 2018Aspirant
EOL Network Switches
Hi
Please, could you say me if FSM726 V2H2 is EOL?
And/or when ?
If EOL, it's replaced by ?
Thanks
Hi PCLease,
The FSM726v2h2 switch is already EOL. If ever you are looking for a Fully-Managed Switch, I suggest you the M4300 series switch models. To know more about the M4300 series switches, kindly access the link below:
DaneA
NETGEAR Community Team
EoL in which aspect? The FSM726V2H2 was launced in 2006, and there were no updates for a while.
Doubt there is any (volume) market for Fast Ethernet managed switches anymore today. What management features (AFAIK there were not many on these models) do you need?
PS. At least, these are not marked EoL yet in the community system yet. ChristineT please check and update.
The links on the firmware release notes are pretty much dead, too
FSM726v2 Firmware Selection Instructions
There are 2 different hardware revisions of FSM726 V2 -
FSM726 V2H1 (Hardware revision #1) & FSM726 V2H2 (Hardware revision #2)
You can identify the revision of your FSM726 V2 from the product serial number:
- FSM726 V2H1 Serial number starts with "171", e.g., 171xxxxxxxxx
- FSM726 V2H2 Serial number starts with "1BV", e.g., 1BVxxxxxxxxx
Important alert before choosing the firmware:
- FSM726 V2H1 and FSM726 V2H2 have different internal hardware components.
- FSM726 V2H2 ships with 1.1.0_0324 by default.
- Do NOT downgrade FSM726 V2H2 firmware to any of the 1.0.x versions.
Hardware VersionLatest Firmware VersionFSM726 V2H1
Version 1.2.5_1016 Jan 20, 2009Version 1.2.4_0324 Apr 15, 2008
Version 1.2.3_1003 Dec 14, 2007
Version 1.2.2_0829 Dec 15, 2006
Version 1.2.1_0728 Sep 15, 2006
FSM726 V2H2
Ships with firmware version 1.1.0_0324 by default.
d102938.asp Aug. 8, 2006Document Type:
Downloads > Driver/Software/FirmwarePublished 02/01/2009 09:52 PM | Updated 08/14/2011 08:58 AM
This product includes software code developed by third parties, including software code subject to the GNU General Public License ("GPL") or GNU Lesser General Public License ("LGPL"). As applicable, the terms of the GPL and LGPL, and information on obtaining access to the GPL Code and LGPL Code used in this product, are available to you at NETGEAR's Open Source Code Web page. The GPL Code and LGPL Code used in this product is distributed WITHOUT ANY WARRANTY and is subject to the copyrights of one or more authors. For details, see the GPL Code and LGPL Code for this product and the terms of the GPL and LGPL.
- PCLeaseAspirant
Hi Schumaku
For the management of obsolescence, i just have to know if this switch is always available(not EoS) and it seems not.
The replacement product must be manageable and have about 16 100/1000 RJ45 ports.
I think that JGS516 or GS716 (if I need HTTPS) are suitable.
Regards
