PCLease
Nov 30, 2018Aspirant
EOL Network Switches
Hi
Please, could you say me if FSM726 V2H2 is EOL?
And/or when ?
If EOL, it's replaced by ?
Thanks
- Dec 03, 2018
Hi PCLease,
The FSM726v2h2 switch is already EOL. If ever you are looking for a Fully-Managed Switch, I suggest you the M4300 series switch models. To know more about the M4300 series switches, kindly access the link below:
DaneA
NETGEAR Community Team
schumaku
Dec 03, 2018Guru - Experienced User
EoL in which aspect? The FSM726V2H2 was launced in 2006, and there were no updates for a while.
Doubt there is any (volume) market for Fast Ethernet managed switches anymore today. What management features (AFAIK there were not many on these models) do you need?
PS. At least, these are not marked EoL yet in the community system yet. ChristineT please check and update.
PCLease
Dec 03, 2018Aspirant
Hi Schumaku
For the management of obsolescence, i just have to know if this switch is always available(not EoS) and it seems not.
The replacement product must be manageable and have about 16 100/1000 RJ45 ports.
I think that JGS516 or GS716 (if I need HTTPS) are suitable.
Regards
