Wristel
Oct 15, 2023Aspirant
Forgotten login/password for my RND400 / NV+
Started up my old NAS yesterday but cant get in the "admin page" in firefox and when i try Safari or google it wont accept my login/password or if its that i dont remember it correctly... dont rememb...
Oct 15, 2023Guru - Experienced User
Wristel wrote:
Started up my old NAS yesterday but cant get in the "admin page" in firefox and when i try Safari or google it wont accept my login/password or if its that i dont remember it correctly... dont remember ever change it thou..
Are you getting to the login pop-up?
Or are you seeing the SSL version and/or Cipher Mismatch error?
- WristelOct 15, 2023Aspirant
not really following.. his is what i get..
- StephenBOct 15, 2023Guru - Experienced User
The NAS admin user name has to be admin. If you can't recall the password, then you can reset it to the default netgear1 by doing an OS reinstall from the front panel.
Instructions are on pages 23-24 of the hardware manual:
However, you will probably run into the SSL protocol version / cipher mismatch issue after you get past this step. That is because current browsers now require TLS 1.1, and the NV+ only supports TLS 1.0
You can work around that issue by using FireFox. Browse to about:config, and then search for the security.tls.version.min setting. Set that to 1. After that you can browse directly to https://192.168.1.194/admin in FireFox and log in (no need to use RAIDar).
