UserHelp2016
May 05, 2016Follower
Forgotten username and Password for ReadyNas NV+ RND4000, How to reset os without losing data
Hi, Forgotten username and Password for ReadyNas NV+ RND4000. How can I reset the device with losing data. I have tried holding the front power button down for 5 seconds to reset the os, but...
mdgm-ntgr
May 06, 2016NETGEAR Employee Retired
Which firmware is on this unit? You can check e.g. in RAIDar.
The default password varies depending on which unit you have and which firmware.
If it is a NV+ running RAIDiator 4.x then it is 'netgear1' (no quotes)
If it is a NV+ v2 running RAIDiator 5.3.x then it is 'password' (no quotes)
If you have a NV+ running RAIDiator 3.x (not sure why you'd want to still run 10 year old firmware but anyway...) then it is 'infrant1' (no quotes)
Also as the v2 is a very different product the boot menu procedure is completely different for it compared with the one for the v1.
