sfpegasus
Jun 08, 2016Tutor
Format NTFS External USB Errors on Win10 machine
I use an external USB drive to backup my ReadyNas daily. It's formated NTFS (by the ReadyNas). Every now and then I need a file from the drive and I take the external drive and plug it into a Win10 ...
Jun 09, 2016Guru - Experienced User
sfpegasus wrote:
When you tell windows not to fix it, you can still access the files and folders just fine (in windows). It's when you remount it in the ReadyNas that the above error occurs.
I was thinking from the earlier posts that you were always letting Windows do the "fix".
Windows isn't supposed to need you to eject the drive anymore, but did you try that too?
sfpegasus wrote:
Maybe I should format it on the windows machine?
That sounds like a logical next step. I'd also look at the SMART stats of the drive (acronis drive monitor is one freeware package you can use for that, though you do need to give them your email address in exchange).
sfpegasus
Jun 09, 2016Tutor
Yeah, I'm kinda old school on ejecting drives using the system tray icon. I'll try reformatting in windows and see how the ReadyNas likes it.
