sfpegasus's avatar
Jun 08, 2016
Format NTFS External USB Errors on Win10 machine
I use an external USB drive to backup my ReadyNas daily.  It's formated NTFS (by the ReadyNas). Every now and then I need a file from the drive and I take the external drive and plug it into a Win10 ...
  • StephenB's avatar
    Jun 10, 2016
    sfpegasus wrote:
    Does the NTFS format utility in ReadyNas have a problem?
    It sounds like it might.
ProSupport for Business
