bamboodyll
Dec 10, 2012Aspirant
frequent network dropoffs
My ReadyNAS NV+ (v1) keeps dropping off the network. I recently switched from share to user security, but this has been going on for much longer. I'll open a file, start to work on it, then the share ...
Dec 10, 2012Guru - Experienced User
Do you recall what firmware it is running? Also did you upgrade the memory?
