bamboodyll
Dec 10, 2012Aspirant
frequent network dropoffs
My ReadyNAS NV+ (v1) keeps dropping off the network. I recently switched from share to user security, but this has been going on for much longer. I'll open a file, start to work on it, then the share ...
Dec 11, 2012Guru - Experienced User
When you can access it, you should look at the SMART and network stats. Failing disks can lock up, which can create a network dropout.
A full OS partition is also possible, that would probably require an on-line support ticket to deal with.
Was this problem happening before the 4.1.10 upgrade?
BTW, it would be prudent to backup up the data (if you haven't).
