bamboodyll
Dec 10, 2012Aspirant
frequent network dropoffs
My ReadyNAS NV+ (v1) keeps dropping off the network. I recently switched from share to user security, but this has been going on for much longer. I'll open a file, start to work on it, then the share ...
Dec 10, 2012Guru - Experienced User
If you log into frontview, you can see both disk SMART stats and network stats.
To see SMART stats, click on status, then health, and then on the SMART+ buttons for each disk. A pop-up will appear showing you the stats. http://en.wikipedia.org/wiki/S.M.A.R.T.
To see network stats, click on network, interfaces, and "show errors". You probably should "clear errors" first, and let it run for a while.
