bamboodyll
Dec 10, 2012Aspirant
frequent network dropoffs
My ReadyNAS NV+ (v1) keeps dropping off the network. I recently switched from share to user security, but this has been going on for much longer. I'll open a file, start to work on it, then the share ...
bamboodyll
Dec 11, 2012Aspirant
Got it. Thanks. SMART data look good for all disks -- all values 0 except for Start Stop Count, Power On Hours, Power Cycle Count, Airflow Temp & Temp.
Network shows some TCP Retransmits and Unrecovered TCP Retransmits. I have since moved the NAS from one router to the other, disabled journaling, and turned off all the streaming services, which I wasn't using. So far, it seems to be more stable and is even happily doing a TimeMachine backup as I type this.
Skimming through the logs, I wondered if any of these entries are cause for concern:
daemon.log
httpd_errors.log
spool_error.log
system.log
user.log
daemon.log
Dec 11 10:24:56 nas-01 avahi-daemon[838]: Withdrawing address record for 192.168.1.3 on eth0.
Dec 11 10:24:56 nas-01 avahi-daemon[838]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.1.3.
Dec 11 10:24:56 nas-01 avahi-daemon[838]: iface.c: interface_mdns_mcast_join() called but no local address available.
Dec 11 10:24:56 nas-01 avahi-daemon[838]: Interface eth0.IPv4 no longer relevant for mDNS.
Dec 11 10:24:56 nas-01 avahi-daemon[838]: New relevant interface eth0.IPv4 for mDNS.
Dec 11 10:24:56 nas-01 avahi-daemon[838]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.3.
Dec 11 10:24:56 nas-01 avahi-daemon[838]: Registering new address record for 192.168.1.3 on eth0.
Dec 11 10:25:10 nas-01 upnpd(eth0)[1724]: Listening on 192.168.1.3:50000
Dec 11 10:25:10 nas-01 upnpd(eth0)[1724]: setsockopt - IP_ADD_MEMBERSHIP: Address already in use
Dec 11 10:25:10 nas-01 upnpd(eth0)[1724]: Failed to add membership for address 192.168.1.3
httpd_errors.log
apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.1.3 for ServerName
Bad free() ignored (PERL_CORE) at /frontview/lib/Frontview.pm line 2.
spool_error.log
warning: commands will be executed using /bin/sh
job 127 at 2012-12-11 15:04
system.log
Dec 11 12:21:36 nas-01 avahi-daemon[835]: Withdrawing address record for 192.168.1.3 on eth0.
Dec 11 12:21:36 nas-01 avahi-daemon[835]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.1.3.
Dec 11 12:21:36 nas-01 avahi-daemon[835]: iface.c: interface_mdns_mcast_join() called but no local address available.
Dec 11 12:21:36 nas-01 avahi-daemon[835]: Interface eth0.IPv4 no longer relevant for mDNS.
Dec 11 12:21:36 nas-01 upnpd(eth0)[2142]: received signal 15, exiting
Dec 11 12:21:36 nas-01 upnpd(eth0)[2142]: setsockopt - IP_MULTICAST_IF: Cannot assign requested address
Dec 11 12:21:36 nas-01 upnpd(eth0)[2142]: bind: Cannot assign requested address
Dec 11 12:21:36 nas-01 upnpd(eth0)[2142]: shutdown: sendto: Network is unreachable
Dec 11 12:21:37 nas-01 kernel: linked, 1000mbps mode
Dec 11 12:21:37 nas-01 avahi-daemon[835]: New relevant interface eth0.IPv4 for mDNS.
Dec 11 12:21:37 nas-01 avahi-daemon[835]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.3.
Dec 11 12:21:37 nas-01 avahi-daemon[835]: Registering new address record for 192.168.1.3 on eth0.
Dec 11 12:21:44 nas-01 upnpd(eth0)[24162]: Listening on 192.168.1.3:50000
Dec 11 12:21:44 nas-01 upnpd(eth0)[24162]: setsockopt - IP_ADD_MEMBERSHIP: Address already in use
Dec 11 12:21:44 nas-01 upnpd(eth0)[24162]: Failed to add membership for address 192.168.1.3
user.log
Dec 10 18:14:27 nas-01 RAIDiator: gmac.agent: "start-stop-daemon -S -q -x /usr/sbin/mt-daapd" failed to start.
Dec 10 18:16:07 nas-01 RAIDiator: gmac.agent: "nice -n 5 /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf" failed to start.
