bamboodyll
Dec 10, 2012Aspirant
frequent network dropoffs
My ReadyNAS NV+ (v1) keeps dropping off the network. I recently switched from share to user security, but this has been going on for much longer. I'll open a file, start to work on it, then the share ...
Dec 11, 2012Guru - Experienced User
I'm not an expert at diagnosing the logs, hopefully one of the netgear support folks will review them.
spool_error.log is completely normal. When did you move the router connection? Some of these messages might be related to that.
Do you have a UPS? If you are running w/o journaling it might be a good idea to have one.
BTW Your router is currently 100 mbit. So your speed limit would be about 10-11 MB/sec.
