bamboodyll
Dec 10, 2012Aspirant
frequent network dropoffs
My ReadyNAS NV+ (v1) keeps dropping off the network. I recently switched from share to user security, but this has been going on for much longer. I'll open a file, start to work on it, then the share ...
Dec 12, 2012Guru - Experienced User
They might not help anyway (sometimes they even hurt). So you should measure throughput with them on and off.
bamboodyll wrote: Thanks for the idea. Didn't get a "packet needs to be fragmented" message, so I think we're good for now. I need to check out all the equipment to see if it can handle jumbo frames. I suspect not, as some is a bit old.
