shaazaminator
Nov 02, 2011Aspirant
Front View, iSCS, SMB/CIFS shares unresponsive ReadyNAS 2100
ReadyNAS 2100 8 TB version 4.2.19 Purchased a 2100 8TB primarily for backup purposes and for virtual test environments. System was live 8-18-11 and both Raidar and Front View updated with latest fi...
shaazaminator
Dec 07, 2011Aspirant
Wow, Ok.
Had to reboot 2008 Server for MS Updates, logging back on the iSCSI Initiator was trying and failing to connect to Favorite Target.
Event Viewer Errors:
iSCSI discovery via SendTargets failed with error code 0xefff0012 to target portal *readynas2100 0003260 Root\ISCSIPRT\0000_0 .
The initiator could not send an iSCSI PDU. Error status is given in the dump data.
Target failed to respond in time for a login request.
For kicks changed the "Teaming Failover" load balancing configured on my ethernet ports from "Round Robin" to "Adaptive Load Balancing" thinking switch configurations may have something to do with the iSCSI connections.
Now I can't even access the FrontView (RAIDar does find the ReadyNas though)
Time for another hard reboot.
