Numb3r6
Oct 17, 2016Apprentice
Frontview and supported browsers
I'm confused. I'm sure I used to be able to use Google Chrome from both Win7 and Win10 PCs to access Frontview on my NAS. The issue is one where it loads, after being presented with a warning about ...
- Oct 18, 2016
Hello Numb3r6,
I don't think it has something to do with the certificates. It's definitely a browser problem as other web browsers do not get the same problem.
You may try downgrading the Chrome and Firefox web browsers that do not work normal with the FrontView.
Numb3r6
Oct 18, 2016Apprentice
Thanks for the interest on this one. Here's a couple of shots:
Chrome (Firefox shows the same symptom)
and IE
as I said before, both give warnings about certificates and I tried to create/export/import into Chrome but it made no difference.
As for IE I just accepted the warning, carried on and the Frontview GUI is fine.
I'm really hoping I'm just missing something stupid here as I'm sure I've managed to get it working previously!
JennC
Oct 18, 2016NETGEAR Employee Retired
Hello Numb3r6,
- StephenBOct 18, 2016Guru - Experienced User
I agree it isn't the certificates.
But current chrome works fine with my duo (running 4.1.15), so I suspect downgrading the browser won't help either.
