Sharpey
Oct 14, 2014Aspirant
Frontview corrupted :(
Hi, It's a long story, but I'll just basically state where I am now. My Frontview v4.1.13 interface looks like this: Everything is working, ie: shares etc, but I only got this far after...
mdgm-ntgr
Oct 14, 2014NETGEAR Employee Retired
Your OS partition is full. Probably due to a large log file.
You can check e.g. using
You may wish to copy the offending log file to somewhere on your data volume then do e.g.
If /var/log/frontview/error.log is the huge log file.
NAS:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 2.0G 13M 100% /
# du -csh /var/*
# du -csh /var/log/*
# du -csh /var/log/frontview/*
# du -csh /var/log/frontview/backup/*
# echo "" > /var/log/frontview/error.log
