Sharpey
Oct 14, 2014Aspirant
Frontview corrupted :(
Hi, It's a long story, but I'll just basically state where I am now. My Frontview v4.1.13 interface looks like this: Everything is working, ie: shares etc, but I only got this far after...
Sharpey
Oct 15, 2014Aspirant
mdgm wrote: If you add a disk while the NAS is on it will be wiped and a resync will take place. Assuming the disks are fine this should work fine.
However if you don't have an up to date backup I would suggest that you backup your data first.
I was intending to shut the nas down, and insert the disk, power back on.
So this will just treat the disk as blank, regardless of the content?
I agree, I should get the lot backed up onto a new drive anyway, just in case.
