Sharpey
Oct 14, 2014Aspirant
Frontview corrupted :(
Hi, It's a long story, but I'll just basically state where I am now. My Frontview v4.1.13 interface looks like this: Everything is working, ie: shares etc, but I only got this far after...
Sharpey
Oct 15, 2014Aspirant
mdgm wrote: I would add the disk while the NAS is on to make sure it is wiped and added to the array. It will wipe it as it is out of sync with the other disk.
Or if you must add it back while the NAS is off, connect the disk to a PC and delete the partitions off it first. If it is the parity disk then perhaps format it and then delete the partitions off it.
If you cold add it it may not wipe the disk and instead fail to boot as the disks are out of sync.
Thanks for the info on this.
How would I know if it's the parity disk or not? I removed the left disk of the two. And from what I can see, both drives have ALL the data on, or is this not actually the case?
