Sharpey
Oct 14, 2014Aspirant
Frontview corrupted :(
Hi, It's a long story, but I'll just basically state where I am now. My Frontview v4.1.13 interface looks like this: Everything is working, ie: shares etc, but I only got this far after...
Sharpey
Oct 15, 2014Aspirant
mdgm wrote: Both disks do have all the data on them except if you were using X-RAID one of them doesn't have the partition table on it as X-RAID uses a dedicated parity disk. Newer models use distributed parity amongst all the disks.
I just RDP'd to my home PC to check, and I'm using X-RAID. Don't think there's even a choice not to or this NAS.
How can I tell what disk I've removed, parity or not? If I've removed the one with the partition table and I add it again to the array and it gets wiped - what happens? :shock:
Disclaimer: I do intend to backup the data (that's not already backed up offline) just in case. :)
