Sharpey
Oct 14, 2014Aspirant
Frontview corrupted :(
Hi, It's a long story, but I'll just basically state where I am now. My Frontview v4.1.13 interface looks like this: Everything is working, ie: shares etc, but I only got this far after...
Sharpey
Oct 15, 2014Aspirant
vandermerwe wrote: If you can read the disk using linux reader and see the data this way, then that is the disk with the partition table on it.
If you can't then the partition table is on the other disk. Disk 1 is usually the one with the partition table on it (the left disk)
The readynas will sync the data whichever disk is still in, it doesn't matter.
Great.....ok, so that'll just rebuild the PT on the currently installed disk anyway?
And does that mean that if I were to get a disk failure on the disk that DIDN'T have the PT, it would then be unreable with Linux Reader? :shock:
Really sorry for all these questions, but I hope this'll help someone else in the future too.
