Sharpey
Oct 14, 2014Aspirant
Frontview corrupted :(
Hi, It's a long story, but I'll just basically state where I am now. My Frontview v4.1.13 interface looks like this: Everything is working, ie: shares etc, but I only got this far after...
mdgm-ntgr
Oct 17, 2014NETGEAR Employee Retired
The logs are truncated automatically on schedule, apart from backup job logs (you may lose valuable info on backups if you truncate those without being prompted).
However if say entries are made excessively e.g. every second, a log file may fill up the OS partition before it can be truncated.
You can move e.g. the ReadyDLNA cache directory to the data volume.
Moving log files even if possible wouldn't be a good idea. The logs can be crucial in situations where the data volume won't mount and if the data volume doesn't mount and logs are on it then they are useless.
