eton
May 16, 2012Luminary
FrontView false warnings
All finished backup jobs appears in Status > Logs. Thats ok, all are green. But FrontView treats them as warnings and every time I log into FrontView it report's new warnings. How to solve this. Is...
May 16, 2012Guru - Experienced User
I see "New alerts detected. Please view Logs." with 4.1.8. I also see/ignore this with 4.2.19 (haven't been running 4.2.20 long enough to tell if it is still there).
readysecure1985 wrote: What is the exact warning it is giving you? Also, make sure you are on current firmware.
It is a nuisance if you run daily backups, since alerts that actually indicate trouble might be overlooked.
