Slavsta
Aug 29, 2009Aspirant
Frontview formats a FOUR tb external drive as a TWO tb ext3!
So I thought I'd found a reasonably priced high-capacity external hard drive for backing up my ReadyNAS: Western Digital My Book Studio Edition II - 4 TB (Mac-formatted out of the box) http://www....
captain1
May 20, 2010Aspirant
Ok, so I think I've figured out how to format my USB drive to contain a big enough ext3 volume to hold my ReadyNAS NV+ data so I can Nuke the ReadyNAS with factory settings and the new firmware which is supposed to allow me to use all the pretty new 2TB drives.
I put the TitanicUSB drive on a Linux box and did this (as root of course):
(replace /dev/sdx with /dev/sdb or /dev/sdc or whichever USB drive you want to partition). Obviously, be sure you pick the CORRECT USB drive, or you'll wipe out that other one you forgot was plugged in. ;-)
# parted /dev/sdx
GNU Parted 1.8.8
Using /dev/sdx
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) mklabel gpt
(parted) print
Model: External RAID (scsi)
Disk /dev/sdb: 6001GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
(parted) mkpart primary 0 6001G
(parted) quit
Use mkfs to format file system (again, replacing /dev/sdx1 with your USB drive designator and partition number):
# mkfs.ext3 /dev/sdx1
# parted /dev/sdx
GNU Parted 1.8.8
Using /dev/sdx
(parted) print
(parted) quit
